Ventilation problem with Sebring
PETERVEE
  • CHRYSLER SEBRING
I have a 2003 Chrysler Sebring Convertible limited (60,000 miles). The ventilation fan only works in the '4' setting and doesn't work in the 0, 1, 2 or 3 settings.
Does this have to do with a relay or fuses, or does the ventilation motor needs changing (assuming of course that it has a separate winding for the 4 setting which works fine).
Does the dahsboard ventilation switch command a relay box or does it directly switch power to the ventilation fan?
I cant find a repair manual, which is why I am trying to get answers here hoping to fix it myself (since I know about both electronics and to a certain extent cars).
Thank you,
Peter
Wednesday, May 31st, 2006 AT 8:09 AM
CRAIGDONNA
[quote="petervee"]I have a 2003 Chrysler Sebring Convertible limited (60,000 miles). The ventilation fan only works in the '4' setting and doesn't work in the 0, 1, 2 or 3 settings.
Thank you,
Peter[/quote]
Monday, October 2nd, 2006 AT 12:21 PM
DENY
  • 5 POSTS
A resistor module is attached to the blower motor plenum either on the firewaLL or under the dash. When it fails the blower only works on high
Wednesday, November 8th, 2006 AT 10:28 AM
