2005 Chrysler Sebring Squeeky spring sound
2005 CHRYSLER SEBRING
CHRMN
Suspension problem
2005 Chrysler Sebring Automatic 54000 miles
Hi! Everytime I go over a speed bump i get a sound from the back that sounds like a very squeeky spring. It's getting worse and even happens with very minor bumps. What do you think needs to be repaired and what would be a reasonable price for repair?
Dec 14, 2009 at 5:16 AM
  • 110,240 POSTS
If I had to guess, I would say the rear sway bar bushings are dry. Try spraying them with something like WD 40 to see if that changes the noise.
If that is the problem, I would think around 150.00 should do the job, but that can change based on where you live.
Let me know what you find.
Dec 14, 2009 at 2:00 PM
