I started out having son to do tune up. Replaced spark plugs, wires, gaskets etc. Noticed a small oil leak so replaced valve cover gaskets. Car was idling at 1500 rpms and I could not get adjusted. Took to dealer and they adjusted a screw in the carb. The car then would not start or when start would stall. Dealer said I need to replace AIS (IAC) motor. I replaced and now car idels at 2600 rpms. Dealer doesn't know how to fix. suggested I clean IAC. Said adjusted all the way out. What are my next steps? Is it the TPS sensor? Throttle body? Throttle cable? I can't detect any vaccuumn leaks.
Perplexed. I am a dumbwoman that needs her car.
Feb 2, 2010 at 4:42 AM
