2002 Chrysler Sebring Valve cover gasket repalcement.
2002 CHRYSLER SEBRING
80,000 MILES • 6 CYL • FWD • AUTOMATIC
08ALLEN
I have oil leak on valve covers. How involved is the valve cover gasket replacement on 2002 Sebring Lxi Coupe V6 engine? Do I have to drain engine coolant? Remove intake manifold? I see the valve cover gaskets sets come with spark plug seals. What other gaskets will I need?
Oct 13, 2010 at 4:02 AM
WRENCHTECH
  • 20,761 POSTS
You will have to remove the upper intake to access the rear cover. You may have to remove some small coolant hoses but you won't lose too much coolant. I would also get an upper intake gasket. The spark plug tubes are part of the valve cover.
Oct 13, 2010 at 4:08 AM
