My car did't start today. I thought it is because of the battery and used jumper but did't work out. What else may cause this problem?
Sunday, October 5th, 2008 AT 8:51 PM
MECHANIC
Hi:
Is the engine turning over for you? If not and you're sure the battery is good, the starter may be bad. On the other hand, if it is turning over but still won't start, there could be several problems.
