Electrical problem
2004 Chrysler Sebring 60000 miles
I need to know how to take the battery out?
Tuesday, July 27th, 2010 AT 1:11 AM
MECHANIC
Disconnect the negative cable first then the position cable. To install battery back do reverse procedure.
SPONSORED LINKS
Tuesday, July 27th, 2010 AT 1:45 AM
MGONZALES1235
MEMBER
The battery is conveinately located behind the driver side front tire. You have to take it off to get to it. There is an access panel that comes right out and its right there.
