2004 Chrysler Sebring CAR WONT START
ZBOYD
  • 2004 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 65,958 MILES
CAR LIGHTS/HORN/RADIO/AND EVERYTHING WORKS. STARTER BEEN CHECKED WORKS REPLACED THE IGNITION SWITCH BX THAT WASN'T IT HAD SOMEONE SAY IT MAY BE THE RELAY RUNNING FROM IGNITIONTO THE STARTER
Saturday, September 26th, 2009 AT 9:40 PM
JDL
  • 16,098 POSTS
Welcome, if it won't even crank, white wire with red tracer at ign switch should be hot. When trying to crank, black wire with red tracer from transmission range sensor to starter, should be hot. Battery is fully charged and connections are good? Did you try cranking in neutral?
Sunday, September 27th, 2009 AT 2:34 PM
ZBOYD
Yes i've tryed to start in neutral no luck also a code comes up on the odmeter it's ( no 6u5) does it mean any thing
Sunday, September 27th, 2009 AT 9:02 PM
JDL
  • 16,098 POSTS
If that is a code, I don't know what it means?
Monday, September 28th, 2009 AT 9:37 AM
Related Engine Not Running Content
