HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
Sebring
Exterior Light
Headlight
Fuse
2004 Chrysler Sebring
SPORTS04
MEMBER
2004 CHRYSLER SEBRING
Electrical problem
2004 Chrysler Sebring Automatic
hi, my right high beam headlight does not work. And I was wondering which fuse I would have to replace to fix it. Thanks.
Tuesday, February 10th, 2009 AT 5:14 PM
OBXAUTOMEDIC
MECHANIC
It is most likely your headlight bulb not the fuse or relay. If was fuse or relay head light possibly wouldn't work at all.
Tuesday, February 10th, 2009 AT 6:01 PM
Please
login
or
register
to post a reply.
Related Headlight Fuse Content
The Marker And Tail Lights Come On But Not The...
When I Turn On The Headlights, The Marker And Tail Lights Come On But Not The Headlights. If I Pull Back On The Lever The Bright Lights...
Asked by
Arachman
2004
CHRYSLER SEBRING
2004 Chrysler Sebring Headlights
How Too Change The Headlight As The Dim Lite No Longer Works
Asked by
john hancock
1 ANSWER
2004
CHRYSLER SEBRING
1998 Chrysler Sebring Headlamp Replacement
I'm Trying To Figure Out How To 'release' The Headlamp Assembly To Change The Bulbs. There Are No Release Pins But There Appear To Two (2)...
Asked by
milehi
1 ANSWER
1998
CHRYSLER SEBRING
1999 Chrysler Sebring
1999 Chrysler Sebring 6 Cyl 119000 Miles How Do You Remove The Headlight To Change A Bulb, On The Driver Side? The Easy Way. Thanks...
Asked by
allensx
1 ANSWER
1999
CHRYSLER SEBRING
Headlight Problem
The Headlight On The Driver's Side Is Dim. Checked Bulb, Not Bulb. Only Purple Wire Has Charge. Green And Black Wire Have No Power....
Asked by
Karen Gendreau
1 ANSWER
2005
CHRYSLER SEBRING
VIEW MORE
How to Use a Test Light
Headlight Dim or Dull
Have a Dim Headlight? - Try Replacing This!
