1999 Chrysler Sebring
ALLENSX
  • 1999 CHRYSLER SEBRING
1999 Chrysler Sebring 6 cyl 119000 miles
How do you remove the headlight to change a bulb, on the driver side? The easy way. Thanks
Surina
Thursday, December 11th, 2008 AT 9:53 AM
ZACKMAN
  • 4,202 POSTS
If this is the convertible:
1. Remove two retaining screw by using T-25 Torx screwdriver.
2. Pull the entire headlight assembly out.
3. Detach the electrical connector.
4. Remove (twist) the bulb retaining ring.
5. Pull bulb out. Touch the base, never touch the glass.
Coupe:
1. Remove (twist) the sealing cover counterclockwise.
2. Remove bulb attaching spring.
3. Remove bulb out and remove electrical connector.
Thursday, December 11th, 2008 AT 8:45 PM
