1998 Chrysler Sebring Headlamp Replacement
125,000 MILES • 6 CYL • FWD • AUTOMATIC
MILEHI
I'm trying to figure out how to 'release' the headlamp assembly to change the bulbs. There are no release pins but there appear to two (2) torx scews at the top to each side that hold the assempby in place, but not sure; of course, i do not have the right size torx screwdriver/bit either. But before I but a set of torzxs I would like to make sure that this is the way these are mounted
Can you confirmt hat this is how the assembly is mounted?
Thansk you - Jay
Jan 10, 2009 at 6:16 AM
ZACKMAN
  • 4,202 POSTS
Yes it is. You will need T25 Torx screw driver to remove them. The entire assembly comes out, remove the wiring harness from the back side, remove the headlight trim ring and pull the bulb out. Install is reverse.
NOTE: Don't touch the glass with your hand.
Jan 10, 2009 at 6:02 PM
