2003 Chrysler Sebring Power Door Lock
2003 CHRYSLER SEBRING
100,850 MILES • 6 CYL • FWD • AUTOMATIC
KOOCYKOO
The power door lock switch does not lock the doors. Have to manually press the door lock plunger/s. But when driving above 20 mph, it automatically locks all four doors (which is the normal thing). Likewise, when opening the drivers door (car at halt), it also unlocks all doors (which is also normal). Is the door lock switch at fault? If yes, how do I replace it?
Feb 5, 2008 at 2:28 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6ed8116af2="koocykoo"]Other Category problem
2003 Chrysler Sebring 6 cyl Front Wheel Drive Automatic 100850 miles
The power door lock switch does not lock the doors. Have to manually press the door lock plunger/s. But when driving above 20 mph, it automatically locks all four doors (which is the normal thing). Likewise, when opening the drivers door (car at halt), it also unlocks all doors (which is also normal). Is the door lock switch at fault? If yes, how do I replace it?[/quote:6ed8116af2]
you can scan the BCM for codes
it sounds like you have a bad switch
Remove door trim panel
Feb 6, 2008 at 9:18 AM
