HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
Sebring
Engine
Symptoms
Overheat
2002 Chrysler Sebring overheating, water leak
KCKS
MEMBER
2002 CHRYSLER SEBRING
6 CYL
2WD
AUTOMATIC
118,000 MILES
Thinking nad hoping water pump
Thursday, January 1st, 2009 AT 6:26 PM
ZACKMAN
MECHANIC
Where is the leak coming from?
Friday, January 2nd, 2009 AT 12:01 AM
KCKS
MEMBER
The water is leaking from behind the pulley system
Friday, January 2nd, 2009 AT 7:50 AM
ZACKMAN
MECHANIC
It is your water pump, then. Replace the timing belt as well, if it has not been done in the last year.
Friday, January 2nd, 2009 AT 6:49 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Why Is My Engine Overheating?
The Gauge To Cooling System Says Normal But Car Over Heats, I Have To Put Water In It When Ever I Use It. Ive Have Plugged It In The Past...
Asked by
Anonymous
10 IMAGES
1998
CHRYSLER SEBRING
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Engine Overheating?
I Have A 2001 Chrysler Sebring Lxi 4 Door Sedan (2.7l 6 Cylinder 4a). It Is Overheating. The Thermostat Has Been Changed, The Hoses Are...
Asked by
texasmoon39
1 IMAGE
2001
CHRYSLER SEBRING
Why Did My Car Overheat?
I've Got A 2004 Sebring Convertible With The 2.7. I've Had Some Issues The Past Few Days With The Cooling System. Yesterday My...
Asked by
SCRE4Sale
2004
CHRYSLER SEBRING
The Is A Convertible Gtc Sebring. The Car Started To...
The Is A Convertible Gtc Sebring. The Car Started To Overheat A Few Days Ago And I Noticed That Thermostat Housing Was Leaking. After...
Asked by
justinthomas1
4 IMAGES
2004
CHRYSLER SEBRING
Engine Cranks But No Start No Signal To Coil
2002 Chrysler Sebring No Start Checked Cam & Crank Sensor With Mt2500 Scanner Shows Signal Have Fuel Pressure No Signal To Coil Timing Belt...
Asked by
billy c
2 IMAGES
2002
CHRYSLER SEBRING
VIEW MORE
Cooling System Pressure Test
