My car won't start. Everthing comes on but it won't crank? Then later on, it cranks.
Wednesday, May 26th, 2010 AT 4:53 PM
BLUELIGHTNIN6
MECHANIC
Try jumpering starter solenoid to see if it engages. If it does then could be faulty ignition switch or faulty anti theft system. Is red anti theft light on when vehicle will not crank?
SPONSORED LINKS
Wednesday, May 26th, 2010 AT 4:54 PM
LJOHN2010
MEMBER
Yes and when I trun th engine on -off-on-off I get a set of codes P1684, P0645, P1388, P1489 what does this mean?
Wednesday, May 26th, 2010 AT 9:49 PM
BLUELIGHTNIN6
MECHANIC
1684 simply indicates that the battery was recently disconnected
0645 is indicating a faulty A/C clutch relay
1388 is indicating a faulty auto shutdown relay
1489 is indicating a faulty high speed fan relay
The one that sticks out to me would be DTC P1388. This auto shutdown relay is most likely the cause of your issues. Check and if necessary replace it.
Wednesday, May 26th, 2010 AT 10:12 PM
LJOHN2010
MEMBER
Am I replacing the fuses or the entire circuit box?
Wednesday, May 26th, 2010 AT 10:37 PM
BLUELIGHTNIN6
MECHANIC
Neither, try replacing the Automatic Shutdown Relay. It is located in the power distribution center (on left front inner fender)
