2000 SEBRING CONV. KEY WON'T TURN.
TAZWILLFIX
We had a problem yesterday with removing the key from the steering column. now the key goes in fine but will not turn. How can I move the transmission into neutral without the key. I think the problem is the saftey lock on the shifter.
Oct 19, 2007 at 6:54 AM
BLACKOP555
  • 10,386 POSTS
sounds like the steering wheel lock is on. rotate the wheel left and right while trying ot turn key
Oct 19, 2007 at 7:17 AM
TAZWILLFIX
I played with that for an hour with no luck. Someone else suggested rocking the car to set the shifter lock and my son is on his way to try that. Any other suggestions? Is there a transmission release to put the car in neutral without the key? Fyi This is a 2000 LXI ragtop.
Oct 19, 2007 at 7:31 AM
BLACKOP555
  • 10,386 POSTS
i dont belive so the only way i know that you could in my experience is to remove the selector rod from the tranny and put it in neutral that way.
Oct 19, 2007 at 7:34 AM
TAZWILLFIX
Rocking the car worked. Now I will have to have the saftey switches inspected. Thanks for the prompt reply and your help. :lol:
Oct 19, 2007 at 7:58 AM
BLACKOP555
  • 10,386 POSTS
thanks for the follow up also. now i will be able to add that to my knowledge and if someone else has the problem i can help them :D good luck
Oct 19, 2007 at 8:10 AM
