1998 Chrysler Sebring Blown Head Gasket
1998 CHRYSLER SEBRING
219,000 MILES • 6 CYL • FWD • AUTOMATIC
CROATON
ok about a month ago my 98 chy sebring overheated. So I checked the coolent and it was low for the first time in 2 years so I filled it up. And It
ran ok until now. last night my car started smoking REALLY BAD (white smoke im sure) so I checked the iol and it was very low and I just filled it the day before and I put an aditive in it called no leak $7 because I had a very little leak 2 drops I took it home and went to bed . The next morrning I turned on the car and I heard a clicking sound about every 10 sec. so I turned it off and left it. I checked the oil and there is nothing rong with it not foaming or anything but my coolent was low again about 2 cups and the resevor was empty. So is this a blown head gasket and if so how hard is it to do it your self and would I need any special tools to fix is
Sep 12, 2008 at 7:19 AM
MERLIN2021
  • 17,250 POSTS
Some enging disassembly is involved, if you have not done this kind of thing before, it's not recommended you learn on your own car! Get a pressure test and or a compression test these will reveal the problem.
Can be a leaking hose, all the way to cracked head or bad gasket.
Sep 12, 2008 at 7:24 AM
