We would need some more information to help you with this. The simplicity of diagnosing the leak would depend on the severity of it. An external leak would be a fairly simple diagnosis.
Symptoms that lead a technician to believe it may be a leaking head gasket could take anywhere from a few test to removing the heads to confirm.
What are the symptoms that make you feel your head gasket is leaking? Get back to me with more info and I will be happy to help if I can.
Dan
Aug 31, 2009 at 12:56 PM
