1995 Chrysler Sebring
DBURCH51
  • 7 POSTS
I have a 1995 chrysler sebring and it has been running great, til the other day i was just driving down the road, and it just quit. Then i tryed to start it and it turns over but will not run. It is not getting any spark, i put a new rotary button and distributor cap on, but same, thing, it turns over but will not run. Any possible answers or troubleshooting methods will be greatly appreciated. And since i am not too car savy, but am anxious to become more mechanically inclined, the more details you can give step by step, would be very helpful. thanks.
Mar 10, 2007 at 4:10 PM
BOOTDOG
  • 665 POSTS
it's possible the fuel pump went out. to check turn the key to the on position without starting,. do you hear the fuel pump? it's a high pitch whine that last only a few seconds. if so make sure there is fuel in the tank. sometimes if the fuel sending unit goes bad, it will give the gauge a false reading, leading you to believe there's fuel in the tank when actually it's empty. if you don't hear the sound then tap on the fuel tank with a hammer while someone else tries to start it. if it starts replace the fuel pump. if not you'll need to check for current to the pump and check for a possible bad relay. try these steps first.
Mar 11, 2007 at 12:02 AM
TOPHER441970
  • 8 POSTS
Mine did the same thing and it was my distributor. i replaced it, and it started up like new. I was getting no spark whatsoever...
May 9, 2007 at 11:30 PM
