Sterring wheel/car shaking @ 75+
1975 CHRYSLER
BEN_HUNTER_760
Hi there,
I currently own a Chrysler Neon RT, Y Reg with 43k.
When I reach up to speeds of 75MPH the steering wheel and car begins to shake, the shaking seems to get worse, the faster I go.
I have had both front wheels balanced which has not solved the problem. I do not notice the car pulling to the side when driving or when braking and have also checked for tyre wear to rule out tracking.
It had a major service and MOT around 5 months at 39k. I have only owned the car for 3 months.
Please Help.
Mar 6, 2007 at 12:45 AM
RETIREDAUTO
  • 46 POSTS
well bennyboy,have you ck'd all of your steering and suspension components(including bushings),if all good try rotating wheels to rear and see if any symptoms change. let me know what you find. ok
Mar 6, 2007 at 9:36 AM
BEN_HUNTER_760
many thanks 'retiredauto', I will check and let you know asap.
regards
bennyboy
Mar 6, 2007 at 7:04 PM
BEN_HUNTER_760
Hey just to let you know I have got it all sorted now.
Asked a friend who said check the rear wheel balancing. got this checked and both wheels were out of balance. problem solved.
lovely drive now.
Thanks for your help
Regards
Ben
Mar 11, 2007 at 9:01 AM
