On my 96 Plymouth Voyager 3.0 keeps on blowing my engine fuse under the hood that is 25 amp fuse. What do i need to do?
Mar 23, 2008 at 8:04 AM
JDL
✓Experienced Mechanic
I'm not sure which fuse your talking about, the fuse for the ASD relay is 25 amp fuse, is that the one?
Does the fuse blow as soon as you plug it in, do you have to turn the key on? Does it not blow till after you try to start it?
Mar 24, 2008 at 1:36 AM
MWAITS1698
MEMBER
It blows when you try to start the engine. It is labeled Engine on the fuse box which is 25 amp fuse can you help me? Thanks
Mar 24, 2008 at 9:36 AM
JDL
Your saying the vehicle won't start when the fuse blows? If the fuse is for the asd relay, you can double check by unplugging the relay, use a testlite on the terminals where the relay plugs in, see if any are hot?
If the problem is on the asd relay circuit, I'd try unplugging the 02 sensors, see if that makes any difference.
Can you check for troublecodes?
Mar 25, 2008 at 2:31 AM
