1999 Other Chrysler Models Headlights Dont Work Properly
1999 CHRYSLER
200,000 MILES • 6 CYL • FWD • AUTOMATIC
DARREN17
my 99 intrepid's headlights dont work properly. when i turn on my high beams, they work fine. i heard it might be the ground wire or something. is that true? what kind of a repair is needed, and how much do you think? thanks
Jan 17, 2009 at 5:20 PM
  • 110,248 POSTS
What happens with the low beams?
Jan 20, 2009 at 11:42 AM
DARREN17
the low beams still i guess work, but very dim. high beams work fine, just the regular headlights dont work. wut do you think is the problem?
Jan 21, 2009 at 11:46 AM
  • 110,248 POSTS
Hi:
It sounds like there is a problem with the ground. If the lights work dimmly, they are getting power. You could pull the plug on the back of the head light and check the plug to see if there is 12 volts there when the low beams are on. If there is less, then I would move to the switch itself.
Let me know what you find.
Jan 22, 2009 at 6:18 AM
DARREN17
what switch are you talking about and where do i move it?
Jan 22, 2009 at 9:20 AM
  • 110,248 POSTS
Hi:
What I mean is if the power supply to the light is below 12 volts, the head light switch itself may be bad.
Jan 22, 2009 at 9:24 AM
DARREN17
so if it is the witch, how would i change it to get the volts up to 12v?
Jan 22, 2009 at 9:36 AM
  • 110,248 POSTS
The front cover on the dash is removeable. You would gain access through there. Before purchasing a new one, however, have your old switch checked to make sure there is too much resistance in it. That way, we can eliminate the high beam switch too.
Jan 22, 2009 at 12:22 PM
