2001 Other Chrysler Models Brake Lights
FORMAN7202
  • 2001 CHRYSLER
  • 4 CYL
  • MANUAL
  • 199,000 MILES
My cars tail lights work but the brake lights wont light up how can I fix this?
Tuesday, January 29th, 2008 AT 8:01 PM
  • 109,885 POSTS
Hi:
Make sure the fuse and bulbs are good. If they are, start at the brake light socket. Using a test light, test for power when the brakes are pushed. If there is power and the bulb is good, the socked must be bad. If there is no power, move to the brake light switch located under the dash / brake pedal. Check for power in and out of the switch. The switch should have power alll of the time. When the switch is closed, the power should run to the brake light. If you have power in and out, there must be a broken wire between the two. If there is power in and not out, replace the switch.
Keep in mind, make sure the brake lever is making contact with the switch. If it isn't, it may just need adjusted.
If you have any other questions, let me know.
Sunday, October 12th, 2008 AT 10:08 PM
