1988 Chrysler New Yorker Spark Plug Location Fix
DARREN
I have just bought a 1988 Chrysler New Yorker and I have been having troubles starting it Im about to change the spark plug but i have never changed one on this car so I was wondering if someone could help me locate it.
thanks muchly
Jan 25, 2006 at 6:37 AM
SC1 RACING
  • 117 POSTS
best thing and easiest i can tell you is to follow the spark plug wires. if you have a v6 you will have 6 plugs if it is a v8 you will have 8.
since you are not sure only remove 1 wire/plug at a time.
Jan 25, 2006 at 6:44 AM
Suggested Repair
Locate the spark plugs by following the spark plug wires. A V6 has six plugs and a V8 has eight. Remove only one wire and plug at a time so the wires are not mixed up.
Conversation Summary
The owner of a 1988 Chrysler New Yorker was having starting trouble and asked how to locate the spark plugs before changing them. The expert advised following the spark plug wires, noting a V6 has six plugs and a V8 has eight, and recommended removing only one wire and plug at a time.
