1992 Chrysler New Yorker auto shutdown
PROSPEROUSONEZ
  • 1992 CHRYSLER NEW YORKER
  • 6 CYL
  • FWD
  • 195,256 MILES
My car won't start because the shutdown for the fuel pump has engaged. I wanted to know is there a way to reset the system.
Monday, October 27th, 2008 AT 1:32 PM
JDL
  • 16,098 POSTS
If your talking about the asd relay, that supplies voltage to the coil--injectors--o2 heater circuit. You need to see if that relay is energized, with the engine cranking. You can also check for codes.
If that relay isn't energized during cranking, one reason might be, that the computer doesn't see the proper cam and crank signals. You need to do some testing.
Friday, November 7th, 2008 AT 8:34 AM
