Chrysler LHS Gas Smell
PTOOTY24
My chrysler LHS smells strongly of gas. What would cause this?
Mar 17, 2007 at 5:34 PM
  • 75,988 POSTS
[quote:ba389c1dc3="ptooty24"]My chrysler LHS smells strongly of gas. What would cause this?[/quote:ba389c1dc3]
Your A/F mixture is too rich-start with the pressure regualtor and coolant temperature sensor and then comeback. Injectors!!!!!!!!
Mar 17, 2007 at 7:00 PM
  • 55,845 POSTS
check the injector rail, it's made of pastic and may be leaking.
Mar 17, 2007 at 7:02 PM
Suggested Repair
Check for a rich air-fuel mixture, starting with the fuel pressure regulator and coolant temperature sensor, then the fuel injectors. Also inspect the plastic injector rail for fuel leaks.
Conversation Summary
The owner of a Chrysler LHS reported a strong gasoline smell and asked what could cause it. One expert said the air-fuel mixture may be too rich and recommended starting with the pressure regulator and coolant temperature sensor, then checking the injectors. Another expert advised inspecting the plastic injector rail for leaks.
