I HAVE A 1997 CHRYSLER LHS. I WOULD LIKE TO KNOW WHERE THE FUEL PUMP IS LOCATED.
Aug 4, 2007 at 4:19 PM
Access the fuel pump through the trunk. Lift the carpet and remove the access panel just ahead of the spare tire well; it is held by four nuts. The fuel tank does not need to be dropped. A Haynes manual is also recommended.
The owner of a 1997 Chrysler LHS asked where the fuel pump is located and whether it is reached through the trunk or by dropping the tank. One reply was unsure, while another explained that the pump is accessed through a trunk panel ahead of the spare tire well, secured by four nuts, so the tank does not need to come down, and suggested a Haynes manual.
