1994 Chrysler LHS TIMING BELT
WAYNE206
  • 1994 CHRYSLER LHS
1994 Chrysler LHS 6 cyl Automatic 150000 miles
HOW DO I FIX MY TIMING BELT
Monday, November 8th, 2010 AT 1:23 PM
WRENCHTECH
  • 20,761 POSTS
This is a very involved and technical job. I really don't advise attempting this as making one mistake will cause your engine to bend every valve in it. If you are determined to try it, then I suggest you buy a service manual for that vehicle and see if you can follow the instructions for timing it.
Monday, November 8th, 2010 AT 3:52 PM
DOCFIXIT
  • 18,828 POSTS
Did T-Belt brake ie. Engine running? If yes job just got bigger engine is an interference engine which means valves contact pistons and bend.
Monday, November 8th, 2010 AT 3:53 PM
