1994 Chrysler Le Baron will not start
HANK57
  • 1994 CHRYSLER LE BARON
  • 4 CYL
  • 120,000 MILES
Drove perefect. Went to leave. No fuel. It cranks fine. I tried starting fluid when I got home. Wanted to run, but not. Fuel inj, I have a book, but I can't understand what it is saying about draining the fuel injector pressure?I can overhaul old motors, but I can't do this newer stuff.
Sunday, August 29th, 2010 AT 9:48 PM
If you can hear the fuel pump come on when you turn key on-check the fuel pressure if its within specs.
Monday, August 30th, 2010 AT 1:16 AM
PLOPPYSATOR
  • 23 POSTS
Did you check the starter relais?
Wednesday, October 20th, 2010 AT 2:57 AM
