1994 Chrysler Le Baron starting and stalling then wont star
LAURIE196342
  • 1994 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 19,700 MILES
I was driving car down the freeway then was loosing power gave it more gas still wasnt going anywhere pulled over then stoped it was stillrunning fine gas it gas then started going again got it home it was fine started it the next morning started fine and ran fine. Got it home again then wouldnt start. Waited till next day started then stalled again. Cant get it to stay running. Could you give me some idea whats going on? Laurie
Wednesday, July 30th, 2008 AT 11:22 PM
Check the fuel pressure and report back the readings. Or you can try below when it cranks over and refuses to start to determine if its fuel or ignition related-
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Wednesday, July 30th, 2008 AT 11:46 PM
LAURIE196342
I have red and mostly white spark after pulling the spark plug wire from the spark plug and grounding it. Could this mean it doesnt have a fuel problem and just needs a tune up? Laurie
Thursday, July 31st, 2008 AT 7:36 AM
LAURIE196342
I also get a click from my under the hood fuse box when trying to start is this suppose to happen? When sitting all night it will start then shut right down. Then wont start till next morning then die again. Can you help me please im really trying to figure this out i;m gonna lose my job if I cant get this car going so please can you help me?
Thursday, July 31st, 2008 AT 8:32 AM
What happened when you used the carb cleaner
Thursday, July 31st, 2008 AT 1:27 PM
LAURIE196342
I DIDNT TRY THE SPRAY, DID TAKE OFF THE FUEL LINE HOSES AND TRYED TURNING IT OVER NO GAS COMMING OUT AND NO PUMP NOISE! COULD THERE BE A SHORT IN THE WIRING BECAUSE WHEN I WOULD WIGGLE THE WIRES AT THE FUEL PUMP IT WOULD START FOR A COUPLE SECONDS.
Thursday, July 31st, 2008 AT 2:33 PM
Check the wiring could be shorting out or bad contact
Thursday, July 31st, 2008 AT 2:39 PM
