1993 Chrysler Le Baron won't start after crash
LUIGIZAMBONI
  • 1993 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 65,000 MILES
Minor impact, cranks fine, will not start. Impact on drivers door hinge and left front tire. All fusible links ok. Is there a crash reset switch? If so where do I find it and what is the reset procedure.
if not, suggestions to check?
Wednesday, September 23rd, 2009 AT 7:01 AM
CH112063
  • 1,320 POSTS
No there is no crash reset procedure. You get hit right where the harness runs to the bulkhead connector and the wires for the fuel pump run to the rear, so I think you have an open. Have a helper get in and check power at green wire at fuel pump(ON HOIST). Then if none follow it back through to the engine to body connector lower left of bulk head also make sure you have current at the interior fuse block. I think the harness may have pulled away or opened between the battery and either one I spoke of. The engine controller is near that area but further forward. Fuel pump green with black tracer. I'll check back every night at around 7 pm eastern standard time. Joe
Monday, October 5th, 2009 AT 10:41 AM
