Hello
Aside from having to keep an eye on your coolant level and having no heat, the leak will also cause rusting and mildew under your carpeting if you let the problem persist.
I do not know your area so I can't answer the question about a reputable shop there. It is a large project to take on. You have to disassemble the dash to reach the heater core. A repair shop is advised if you do not have much experience with mechanics. I have below an estimate for replacing your heater core at a repair shop.
Thanks for using 2CarPros.com!
SPONSORED LINKS
Monday, January 19th, 2009 AT 11:34 AM
