1992 Chrysler Le Baron No heat
1992 CHRYSLER LE BARON
12,288 MILES • 6 CYL • 2WD • AUTOMATIC
MUSTANGGRANNY
This LeBaron does not have heat. The A/C works fine and blows cold air. The fan blows fine. The selector buttons do not seem to be working properly. It does not switch from defrost to floor, and etc. Do you have any suggestions as to what could be the problem and what to do about it?
Nov 21, 2008 at 11:32 AM
  • 110,244 POSTS
Hi:
Is the problem no heat or fan direction? If direction, the vents are actuated by vacuum. Check under the dash for leaks and the vacuum supply from the engine. If all are good, then chances are it is the switch itself.
If the heat itself it the problem, let me know.
Mar 17, 2009 at 3:34 AM
