Heater problem
1990 Chrysler Le Baron 6 cyl Two Wheel Drive Automatic
no heat is coming into the car. There is anti-freeze in and all the hoses that are supposed to be hot are.
Friday, December 26th, 2008 AT 4:02 PM
MECHANIC
Is the blower motor operating? If so check the thermostat and heater core if okay the problem could be an air mix/blend/mode door, vacuum and actuator, HVAC control module.
