Transmission problem.
CHRYSLER GRAND VOYAGER
DLPT2A
Dodge grand caravan 1996, 150,000 M Transmission rebuilded 3 nonths ago, the problem came on only two weeks ago
It is allways the same. Driving over 45 miles My wipers go on one time just before the trannyl suddenly downshift to 2nd gear and does not go any higher. When I you pull over, put it in park, kill the engine, and then re-start it, it works fine for another two o three days. I did a computer scan and I got a transmission relay code, I don't even know where that relay is or if can be a problem in the circuit some where before or after the relay.
At least with the wiper thing I get a warning before happens so I can slow down
Feb 4, 2006 at 10:17 AM
DLPT2A
I was a bad ground, the one under the hood at the passanger side, Just loose it up clean it and put it bak nice and tie. Works perfect now.
Feb 11, 2006 at 8:33 AM
