2003 Chrysler Grand Voyager Leaking Transmission Sump
2003 CHRYSLER GRAND VOYAGER
75,000 MILES • 6 CYL • FWD • AUTOMATIC
ARKUS1307
It appears that the bottom of the Transamission sump is leaking oil. Where could that be coming from and how do i stop it?
Jul 1, 2009 at 4:51 AM
  • 110,244 POSTS
Is it the transmission pan? If so, the only thing you can do it replace the gasket. When you do it, you will loose about 4 qts. of ATF, so make sure you are careful not to spill it on yourself. Also, just buy a kit and replace the gasket when you do it.
Oct 11, 2009 at 3:01 PM
