2002 Chrysler Concorde wont start
GREYCLOUD
  • 2002 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 108,000 MILES
The car will not start. The battery and the starter both checked out fine, cables are good too. Latley if the automatic lights are left on it was running down the battery so have been turning the lights on manually. Any suggestions as to what to look for next. Car has been well maintained. Regular oil changes/replaced thermastate with in last 6 months.
Wednesday, September 1st, 2010 AT 7:52 AM
JDL
  • 16,098 POSTS
Did you check the starter relay circuits? Red wire is hot/voltage all the time. Yellow wire with black tracer goes hot/voltage with key in the crank position. Both circuits have fuses. Use a voltage tester on the circuits, Also, your computer grounds the coil side of the starter relay, if no ground, could be problem with security system?
https://www.2carpros.com/forum/automotive_pictures/170934_concorde_lx_starter_circuit_1.jpg
Wednesday, September 1st, 2010 AT 2:45 PM
