2001 Chrysler Concorde not starting all the time
MDKERN1970
  • 2001 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 120,000 MILES
This problem just started happining. When I start the car it it does'nt start but makes a clicking noise. All the dash warning lights flash as well as it makes the clicking noise! If I keep trying to start it eventually it does start. I am pretty sure it could be a few different things such as (battery, battery water levels, starter, or solinoid.)?
Sunday, March 15th, 2009 AT 10:26 AM
  • 109,885 POSTS
It sounds like a bad solenoid. Remove the starter and have it bench tested at a parts store. If the solenoid is bad, replace it. Or, it is easier and not that much more to replace the entire starter.
Monday, March 16th, 2009 AT 1:39 PM
MDKERN1970
It was the negative battery post. It was corroded! I couldn't see it cause my battery is in the fender well under the air filter. Thanks for your response though.
Tuesday, March 17th, 2009 AT 4:05 PM
