I'd make sure the battery has a full charge and the connections are good. Next, I'd check the circuits at the starter relay in the power distribution center under the hood. You can unplug relay, use testlite, how many hot terminals, key in crank position, should be two?
Tuesday, October 20th, 2009 AT 10:43 AM
