2000 Chrysler Concorde Car won't start but will crank
ROBJRIB
  • 2000 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 108,000 MILES
The car is a 2000 Chrysler Concorde with the 2.7 L. V6 engine. The problem is that the engine cranks but will not start. I replaced the crankshaft/camshaft sensors, spark plugs and checked the wiring (within reason). The car is equipped with power door locks and keyless entry and the factory vehicle security system. I am baffled beyond belief. Please help.
Friday, January 2nd, 2009 AT 7:06 PM
ZACKMAN
  • 4,202 POSTS
Just to be on the safe side. Reset your alarm system. Close all doors, and use the key to lock the driver side door. Wait a minimum of 45 second to let the alarm turns on, and then use the key to unlock the driver door.
To make sure that you have fuel, you may want to test for fuel pressure (minimum 40 psi) at the fuel rail.
Friday, January 2nd, 2009 AT 7:26 PM
