1999 Chrysler Concorde PASSENGER SIDE MIRROR REPLACEMENT
86,750 MILES • 6 CYL • FWD • AUTOMATIC
MITCH0350
I NEED INSTRUCTION FOR REMOVING AND REPLACING THE PASSENGER SIDE MIRROR ON A 1999 CHRYSLER CONCORDE LXI?
Nov 2, 2009 at 12:47 PM
CH112063
  • 1,320 POSTS
Is this a power mirror? or manual remote with the joystick? The cover inside came off, and you found three 10mm nuts. Deep socket, 1/4 inch drive. The length of the connector, and/or Knob, would tell you if the trim panel had to come off and it usually did not. Sometimes that panel that was black, inside had a hidden screw inside, and it required the door panel removal. If the joystick type was on the mirror, you needed a tiny allen handle, and on the door, the joystick cover screwed off normally counter clockwise. The newer mirrors and the smaller ones used 3 plastic sheet metal screws. Instead of nuts. Sorry I don't have the LH manual but the 2carpros does.
Nov 6, 2009 at 12:49 PM
JOEL SMITH
I have a 99 Chrysler concord lxi it's a power mirror, what do I need to replace it
Aug 18, 2019 at 2:52 AM
This process is going to be the same. If you remove the interior trim piece that is on the inside of the door where the mirror is, you will see 3 nuts. Remove these and the mirror will pull off the outside of the car. Then you will find a connector inside. Disconnect the connector and then install the new mirror.
Aug 18, 2019 at 4:56 AM
