2004 Chrysler Concorde drivers side window
2004 CHRYSLER CONCORDE
100,100 MILES • 6 CYL • FWD • AUTOMATIC
DAVEJN71
all of my windows roll down except the drivers side they are power windows. what should i check
Jul 28, 2008 at 11:23 AM
  • 110,244 POSTS
Hi:
Remove the door panel and check for power when you hit the switch.
If no power to switch, check fuse / wiring
If there is power to the switch but none to the motor, replace the switch
If there is power to the motor but it doesn't work, replace the motor.
Oct 21, 2008 at 1:58 AM
