REPLACED THE CRANK & CAM CENSOR, TIMING BELT, REBUILT ENGINE COMPUTER AND CAR WON'T TURN OVER.
IT CRANKS ON BUT WON'T START
Friday, April 10th, 2009 AT 2:44 AM
MECHANIC
Do you have power to the coil if not check and test the ASD relay
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
