1996 Chrysler Concorde my car is smoking
1996 CHRYSLER CONCORDE
121,000 MILES • 6 CYL • FWD • AUTOMATIC
SBATESR
my car is a 1996 chrysler concorde, about 7 mths ago it was miss firing and i took it to the shop but they couldnt figure out why it was missing. Then the car had this loud noise from it like 3mths later i took it to the shop and they said it was the catalytic convertor. the noise stopped but a couple of days later i took it back to see if they could figure out the miss again and he notice that the catalytic convertor was very hot. so i got the vacuum test done and i had to get the intake gasket replaced. Ok now last week the car was running hot, so i replaced the thermostat. the smoke stopped and the car was running fine, so today i noticed that smoke was coming from the inside of the car near the radiator and a liuttle was coming from the tail pipe, i looked closely to make sure it was coming from there and it looks like it was. my husband got me to back my car up cause we smelled antifreeze and when we looked down there was a little puddle of anti freeze on the ground. Do you think its my head gasket or something else?
Oct 13, 2008 at 4:05 AM
DOCFIXIT
  • 18,828 POSTS
If you have antifreeze comming from tailpipe then yes head gasket is bad. Or they did not get intake gaskets on properly and fluid is lealing there and would enter combustion chamber and out tail pipe.
Oct 14, 2008 at 5:49 AM
SBATESR
the antifreeze was in a little puddle at the fromt of the car, not the tail pipe, does thisstill mean that it is the head gasket
Oct 14, 2008 at 7:07 AM
DOCFIXIT
  • 18,828 POSTS
Check radiator it is plastic and may have a crack.
Oct 14, 2008 at 7:31 AM
