There is a CU box that works the directionals/hazards so i've been told. It has been drawing all the power from my battery. Runs fine once jump started but 'blinkers' still don't work.
i was curious is to what the part is called and where it is located (how to get to the part myself)?
SPONSORED LINKS
Monday, November 30th, 2009 AT 12:20 PM
MECHANIC
Actually, the "combo flash relay" is part of the multifunction switch on the column. It will be a dealer part unless you can find one in a salvege yard.
