1998 Chrysler Cirrus Won't Start
CIRRUS
  • 1998 CHRYSLER CIRRUS
  • 6 CYL
  • 53,000 MILES
I drove it yesterday, and the only problems I've had with it (in the week since I bought it!) Have been that it takes a moment for the engine to turn over.
When I turn the key, the mileage lights up, and the little indicator for what gear I'm in. But not a single sound comes from the engine. And the clock and radio don't work, no matter which way to turn the key. But the windows and the lights work fine!
A friend suggested that it's a bad wire (we already checked the fuses), and I'm wondering how long this will take, and how expensive it's likely to be.
Thanks!
Tuesday, November 4th, 2008 AT 7:51 AM
  • 109,885 POSTS
DId you check the fuses for the radio?
The starting problem is a good question. It could be the ignition switch itself. Does it make any noise before finally turning over?
Wednesday, November 5th, 2008 AT 4:53 PM
CIRRUS
The engine was making no noise at all, and not turning over.
The problem, which was about $250 to fix, was that the starter went bad and took s fuse with it.
Thanks for your reply!
Thursday, November 6th, 2008 AT 6:50 AM
