1997 Chrysler Cirrus distributor
1997 CHRYSLER CIRRUS
75,000 MILES • 6 CYL • FWD • AUTOMATIC
BT2009
Can we change the transistor in the distributor which seems to fail, causing a no start issue(no spark condition). It seems that replacing the transistor will correct the problem. If so, can you suggest a source for the transistor and tell us the specs for the transistor purchase. If not, please advise how we might effect a repair in the most cost effective manner. The distributors are very expensive. Please note that the ignition coil is good.
Dec 12, 2009 at 5:17 AM
BLACKOP555
  • 10,386 POSTS
they should sell the new transistor from a autopart store. just tell them what you need.
if you still cant get it from a autopart store or a dealership get back to me and ill tell you the specs.
Dec 12, 2009 at 11:24 AM
