1996 Chrysler Cirrus Help!
1996 CHRYSLER CIRRUS
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTY11
  • 5 POSTS
The car has little or no acceleration. We replaced the fuel filter, spark plugs, hoses, air valves, sensors, distributor cap and rotor. The fuel pump seems to look good. Any suggestion?
Mar 22, 2010 at 5:48 AM
LEGITIMATE007
  • 5,121 POSTS
check your fuel pressure, sounds like your not getting the correct amount of fuel,
Mar 22, 2010 at 2:19 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
timing may be off too, you can test compression to see if this is the case
Mar 22, 2010 at 2:20 PM
LEGITIMATE007
  • 5,121 POSTS
MARTY11
  • 5 POSTS
The timing is fine so is the compression. The fuel pressure is fine. We replace the crank sensor and got a little better. Any more suggestion? Do you think it's the pcm unit? Please help!
Mar 23, 2010 at 12:21 PM
LEGITIMATE007
  • 5,121 POSTS
check the catalytic converter, throttle position sensor , I dont want to jump on the computer just yet.
Mar 23, 2010 at 2:47 PM
MARTY11
  • 5 POSTS
We checked the catalytic converter, throttle positon sensor are good. ??
Mar 24, 2010 at 4:49 AM
LEGITIMATE007
  • 5,121 POSTS
clean the mapp sensor out, the computer is all that is left besides the torque converter. check the solenoid too. after that, the only thing left is the computer. after all is supplies the grounds for everything on the engine.
Mar 24, 2010 at 7:04 AM
MARTY11
  • 5 POSTS
Is there another solenoid besides the starter solenoid? If so where is it located? Also where is the mapp sensor located? Torque converter is fine.
Mar 24, 2010 at 1:01 PM
MARTY11
  • 5 POSTS
Well I checked the mapp sensor and the solenoid...negative....
Mar 26, 2010 at 2:16 PM
