1997 Chrysler Cirrus takes many cranks before it starts
102,675 MILES • 4 CYL • FWD • AUTOMATIC
SASHA3732
vehicle ran ok and one day it started to take many cranks before it would start fuel guage didnot work replace fuel leveling unit but didnot fix my starting problem and check engine is on with a code po1495 checked for spark and have no spark for a second or two then fires up can it be related to a ground problem associated asd relay.
Jan 17, 2008 at 2:01 AM
MASTERTECHTIM
  • 4,750 POSTS
i just looked up code 1495 and its for a leak detection pump problem, most likely not related to your problem. it could be the asd relay, cam or crank sensor. hope this helps. feedback and votes are appreciated
Jan 17, 2008 at 2:12 AM
