1996 Chrysler Cirrus cumputer
TFIRECAPT
  • 1996 CHRYSLER CIRRUS
  • 6 CYL
  • FWD
  • 140,000 MILES
If the pcm/eum goes out will that keep the car from starting?
Monday, April 26th, 2010 AT 12:16 PM
Yes it will-but do below before you do it
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, April 27th, 2010 AT 3:08 AM
