HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
300
Drivetrain
Transmission
Gear Selector
Stuck
SPONSORED LINKS
2006 Chrysler 300 stuck in park
JACKSON T
MEMBER
2006 CHRYSLER 300
6 CYL
2WD
AUTOMATIC
100,000 MILES
The vehicle will start but will not allow me to shift out of park. Never has happened before.
Sunday, May 30th, 2010 AT 10:03 PM
BLUELIGHTNIN6
MECHANIC
Check to see if your brake lights are working. If not then the brake light switch may be at fault. Also check fuses
SPONSORED LINKS
Sunday, May 30th, 2010 AT 10:29 PM
JACKSON T
MEMBER
Where is the brake light switch located
Sunday, May 30th, 2010 AT 10:39 PM
BLUELIGHTNIN6
MECHANIC
Just above brake pedal, under driver dash
Sunday, May 30th, 2010 AT 10:40 PM
Please
login
or
register
to post a reply.
Related Transmission Gear Selector Stuck Content
2006 Chrysler 300 Gear Wil Not Move From Park
My Car Is Stuck In Park And Will Not Move.
Asked by
clydecarrington
2006
CHRYSLER 300
2006 Chrysler 300 Shift
I Parked My Car In My Garage And The Next Morning I Started My Car But It Would Not Shift Int Reverse. The Shifter Will Not Move.
Asked by
ccrider9
2006
CHRYSLER 300
2005 Chrysler 300 Transmission Shifter Stuck In Park
It Appears To Be A Common Problem In Chrysler 300s To Have The Transmission Shifter Sticking In Park. It Apparently Is Associated With The...
Asked by
deltajfd
1 ANSWER
2005
CHRYSLER 300
2007 Chrysler 300 Stuck In Park
Car Has Been Normal, I Used The Remote Start And Car Will Not Shift Out Of Park. I Turned Car Off And Started Normal And Still Will Not...
Asked by
rvmack
2007
CHRYSLER 300
2005 Chrysler 300 Shift Lever Stuck
Our Chrysler 300 Is Stuck In Park. With Key Turned On And The Brake Pedal Depressed The Shift Lever Moves To The Right But Not Back Towards...
Asked by
Pat Gilkey
2005
CHRYSLER 300
VIEW MORE
SPONSORED LINKS
Transmission Service 65RFE RAM 1500 2013-2022
Transmission Filter and Fluid Replacement
Transmission Problem Repair - Automatic
Online car repair manuals
