2006 Chrysler 300 Shift
2006 CHRYSLER 300
52,132 MILES • V8 • 2WD • AUTOMATIC
CCRIDER9
I parked my car in my garage and the next morning i started my car but it would not shift int reverse. The shifter will not move.
Aug 27, 2010 at 5:07 AM
MADMIKE1735
  • 951 POSTS
assuming your foot was on the brake, did you force the shifter??? also, were u parked on an incline of any sort??? if the engine is not running, key on, foot on brake, can u move the shifter? if so, put it in neutral start the car, and see if that happens again.
Aug 28, 2010 at 3:57 PM
CCRIDER9
[quote:2534c331f1="madmike1735"]assuming your foot was on the brake, did you force the shifter??? also, were u parked on an incline of any sort??? if the engine is not running, key on, foot on brake, can u move the shifter? if so, put it in neutral start the car, and see if that happens again.[/quote:2534c331f1] The shifter will not move at all. Can't move it to R, N, OR D. No I'm not parked on an incline
Aug 30, 2010 at 2:01 AM
